Radio Shack Pro-97 Handheld Scanner Logo
Posted on Aug 16, 2007
Channels locked out
All the channels on my scanner read locked out. When you look at it it looks like 1 + and looks like this for all of them. I have done everything I can find in the manual to no luck.. HELP!
  • 1 more comment
  • Jann88 Feb 08, 2008
    Turned on scanner it reads All channels locked out. What can I do to get the scanner to start scanning again?
  • Anonymous Feb 15, 2009
    still have the words all channel lockout when i hit scan
  • Anonymous Apr 23, 2009
    My batteries ran out. When I put new batteries in it says All Channels Locked out. HELP!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 26, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6988
Points
25
Mrs. Santa brought me a new PRO-97 yesterday. I'm new to this - just wanted an aircraft frequency scanner, but got the whole shameal. I had a bad AC adapter and attempted to fix the power problem as directed in the manual by re-initializing the scanner. That blew all memory away.
I received the feared All Channels Locked Out message and through a little research and fiddling, realized the scanner was pre-programmed. An Addendum came with the scanner with instructions to reload the 155 pre-programmed frequencies:
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
Best wishes,
Farnk
  • Anonymous Aug 03, 2012
    Hey thanks....worked for me
Anonymous
Level 1:
  • Contributor 56 Answers
  • Posted on Aug 16, 2007
Anonymous
Contributor
Level 1:
Answers
56
Questions
0
Helped
32799
Points
96
Press the scan button then press the numbers 12345 and 6, see if this changes the numbers at the top (showing which banks you want to scan through) if this doesnt seem to change, press the manual button multiple times and see what kind of channels you hvae programmed in. if they're all 000.000000 or such, or all have l/o at the bottom, i believe it's the S/S button (says lockout over it) press this after choosing a manual channel that you want to be able to scan through. see if this changes anything
Can't unlock channels they are all showing l/o.
Look to see on the keyboard that has a button that looks like a key with a
border around that button. That'll be you L/O button place the scanner on
Manual then keep pressing Manual for each channel. If you see the letters
L/O << looks like that press the lock out key the those letters "L/O" Should
Disapear.. Keep doing those steps untill all channels a clear.. I say this
because this is how my Uniden 30 channel hand held works..
Yours may work diffrent? Hopefully it works the same.
2answers
Radio Shack Pro 97 - Talk Group Problem & All Channels Locked out_ Re-Posted
restore the factory defaults .turn off n then on agn after 5 mins.this may help.wish u success bye.
5helpful
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
1helpful
BC72XLT scanner does not stop on some programmed channels while scanning. My other scanner will read the transmission. The numbers indicating banks 1 and 3 aare not visable during scan, are they locked...
what it is because that your other banks are locked out and thats why it by passes your frequencies...unlock your banks and it will stop on the transmissions...
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Scanner is locked on bank 6, how do i unlock
Well first off, their are no "banks". this is a 10 channel scanner. Press the "Man" button to scroll through the 10 channels, or pres Man and buttons 1 to 10 (1+0) to move to that frequency. Buttons no work, press "LOCK".
4helpful
3answers
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
2helpful
3answers
2helpful
2answers
Link: http://support.radioshack.com/manuals/ome20-525.pdf
You must complete a reset, see owners manual above link and see page 83.
Note: Please vote for me..
Thank you!
Top Radio Shack Radio Communications Experts
John
John
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
