Rm cy25 service manual
Compal manufactured this computer and it was sold under many different manufacturers names.
To remove optical drive: Extract the two screws in the base that obviously attach to the drive. Remove cover from memory, roughly in centre of base, and you will see a screw that secures the drive. Remove the screw and the drive will slide out. Remove the bracket on rear of drive, attach to new drive and reverse above procedure. Memory is located under the said cover and also under the keyboard. Not too difficult to remove keyboard. Remove switch panel after removing screws in back of hinges. You will see several screws on rear of keyboard. Remove these (very small) and keyboard will swing upwards and out. Beware ribbon cable connector underneath as removing keyboard. You will then see second memory location. Max mem 1G
