Dryers Logo
Posted on Mar 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Knemore 80 series dryer won't start every time
Kenmore Seriies 80 gas dryer
Model #76822690
Dryer was working fine and just stopped turning on. When the start button was pressed it ''buzzed'' but would not start.
The next day dryer started right up and ran for about 2 hours - then stopped again. Buzzed for a couple of pushes of the start button and then stopped all together.
I cleaned out the vent and lint screen and dryer started again.
Next day, only buzzed when pushing start button - but would not start.
Today, started fine and ran for a few hours but started to have a ''electrical'' smell so we turned it off.
I also checked to see if the air flow was appropriate - air flow was fast and very warm.
No consistancy on whether or not it will start - now we have to hold the button in for a few seconds before it will start....that is, when it actually starts.
I also really need a schematic of the dryer.
Anonymous
Level 3:
  • Master 686 Answers
  • Posted on Mar 20, 2009
Anonymous
Master
Level 3:
Answers
686
Questions
0
Helped
249001
Points
1652
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
My series 80 Kenmore dryer won't start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
My dryer wont heat up.suddenly stopped heating...rotates just fine.. Kenmore 400 seriies gas dryer..please help
Make sure to check all the thermal fuses in the dryer.
if one of the has not got any continuity then replace it.
there is also a chance that the ignitor has gone bad and is not allowing the gas valve to open.
Jul 03, 2010 • Dryers
1helpful
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 • Dryers
I have a used Kenmore Series 80 dryer & the drum stopped turning
Good day,
Not hard to do but check the 2 rear wheels that support the drum and change at the same time if needed. Inspect the belt tensioner as well.
Here's a good tutorial on the belt change.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 15, 2009 • Dryers
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
1helpful
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
3helpful
2answers
Location of the thermal fuse on the kenmore gas dryer 80
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2009 • Dryers
Kenmore gas dryer no flame
if ignitor glows but fails to ignite suspect coils on burner valve
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
