If only one button do not work, it might be set right by cleaning it. But to clean it, you must open the remote control If you check the link given below, you can get the procedure about how to clean , repair and check a remote control http://electronicshelponline.blogspot.com/ Pull up older posts there.
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY... I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else. P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
With your model number at hand, check the RCA website for a later code list.
If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes.
At best, these should be called (honestly) 'multi-brand.'
Answer:According to Apex, you can disable the parental lock using the following information.
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
One of the above methods should get you past the lock. If so, I would take the opportunity to disable the lock in the TV's menu so this doesn't happen again.
If this still doesn't work, you can call Apex Customer Support at (800)880-1227.
Turn on the TV
With the remote press the F button and the Mute button at the same time. This should bring your TV back to normal mode. from Don "the TV King"
