SOURCE: my graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
SOURCE: err: no sign chng
When you get the sign change error it is either that you have mixed up the left bound and the right bound or that you are marking the left and the right bound both above the x-axis or both below the x-axis. That's why you get the sign change error. Your range values must have different signs.
SOURCE: When graphing says ERR: INVALID DIM 1:Quit
You have two lists that don't agree in length.
Solution 1 (easy)
Press [y=] and look at the top line - one of your Plots is highlighted.
Move the arrow to the highlighted one, press enter to get it un-highlighted.
Solution 2 (permanent)
Press [STAT] - EDIT: [1] to edit your lists. Go to the bottom of the lists and see which one is the longest. Delete (DELETE, not clear) the "extra" entries in the longest list until all lists are the same length.
SOURCE: WHen trying to graph anything, ERR: INVALID DIM
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
