Contributor
- Posted on Mar 20, 2009
Re: Filter grid alignment
First, I don't understand why I could not submit my question when the filter model I have was not listed in the drop-down of models. As I wrote in my question, I had to choose the wrong filter, JUST to get the question submitted. NOTE: This instruction is for Hayward DE filters. Mine is a DE 6000, but I believe the instructions apply to all sizes.
I did solve my question by:
- Place the grid manifold upside down on a flat surface. (Holes up, remove the air escape tube first.)
- Start with the SMALL filter grid(1 of 8) and insert it in the location hole to the left of the stand pipe inlet. (The LARGE hole in the manifold.)
- Continue inserting the remaining 7 filter grids counterclockwise into the location holes, with the tight curl of the grid going toward the center.
- The base plate (circular swirl piece) is now worked onto the filter grids, BEING SURE THE "CUT-OUT" FOR THE STANDPIPE ALIGNS WITH LARGE MANIFOLD HOLE, where the standpipe will be.
- I found working from the center outward, and giggling the plate as I progressed, the filter grid ends worked their way into place. You'll know it's in place when the plate feels solid and is parallel with the manifold. The filter ends will be in the correct notches and the grids will be symmetrical.
- Drop the stainless center rod (with washer and nut in place) through the base plate and into the hole in the center of the manifold.
- Holding the assembly together, by pressing the base plate and manifold together (with one finger on the rod), turn filter grid assembly over.
- Place washer, and tighten nut, on top of rod. Replace air escape tube and tighten clamp.
- Lightly lube the standpipe with Vaseline and place the filter grid assembly into the bottom filter housing.
- Lightly coat large "O" ring with Vaseline and place onto top lip of bottom filter housing.
- Place filter housing top on top of the filter housing bottom, being sure to create an equal size gap between the 2 pieces.
- Place the clamp ring around the seam and tighten both screws until the springs are completely compressed. (There will be a slight gap between the clamp ring halves.)
- Fire up the pump, add fresh DE through the skimmer return line to the filter, and enjoy your pool.
