Recent got the wireless usb adapter for my Dell Desktop. I have run the software and the device is detecting the internet but it keeps telling me there is a problem because it is unable to renew the ip...
First, make sure that that wireless card is configured to obtain an IP address automatically, unless you are at work and they give you a static IP address. You can check the configuration by going to the properties page of the wireless adapter. You get to this page through Control Panel > Network and Internet(or something similar depending on version of windows) Right click on the wireless connection and go to properties. Right click on TCP IPV 4 and the settings should be set to auto obtain ip address.
If you are using a static IP address, then you have to manually type in the ip address in the window above.
Try the following to renew the IP address.
Turn off the cable modem, the router and your computer. After 10 seconds, plug in the cable modem, after 20 seconds, plug in the router, after 20 seconds, turn on your computer and see if this helps.
Another option to renew the ip address is the following,
Go to Start > Run and type "command" or "cmd"
Then type "ipconfig /release" once this is done type "ipconfig /renew"
If this helps thumbs up my solution!
Regards,
G33k
my wired xbox360 get an internet connection, my laptop gets sn internet connection from my router but the wireless xbox360 with adaptor does not get a connection but yes green light is on as snd it says connected but no ip address
