The oven won't come on, the digital timer just flashes continuous
The timer/digital clock just flashes and when I turn to say grill, temperature to set, it comes on for a second and turns off. No indication of both nobs red light showing.
Sorry, it won't let me set the clock as well again the figures just flashes and doesn't turn the oven on!!! HELPSorry, it won't let me set the clock as well again the figures just flashes and doesn't turn the oven on!!! HELP
You can't post conmments that contain an email address.
Try turning off the power for 3 minutes to try and reset the clock module. If this does not work it will need the clock replaced or a clock by pass done. A good electrician can do this.
Both the top and bottom oven will only work if a time (any time) has been set on the clock. Setting the time operates a contact to switch the power through. The only exception is the grill. This will work even if the time has not been set. So if the oven controls/lights and heating work, to me it means that the clock/timer is half working and the only thing that isn't is the display.
I haven't had the clock/timer to bits but a fellow blogger has said that in some timers there is an electrolytic capacitor that controls the display. When this fails as they are renowned for doing, the dispaly mal functions. If there is one then Maplin have some - VHR41W/43W and DT64U depending on value etc. Let us know how you get on.
If you need a new clock/timer they are around £80 from espares.
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
if you are having trouble setting the clock times etc this is probably down to a worn bit generator this is the knob you turn to set the time they get dirty when using oven or grill and wont operate properly,the clock will need changing im afraid as there no way to open the clock without destroying it.
