Replacing the spring pin is not a problem, however for the band to look as it did originally, the end piece, or end tab - which is now missing, must be replaced. These parts are generally proprietary. You can order one from your local Certified Master Horologist.
You may also consider contacting Luminox. Sometimes, the manufacturers run out of these parts and the whole band must be ordered because that is all that is available.
Those type of bands take a special push pin to push out the pins and can be rather tricky. My best advice would be to take to a local jeweler/watch repair as they have the best tools to do it and it normally is less the $15 to do and worth it.
Hope this helps.
If you have a new wristband, there is a spring loaded lug where the band joins the watch, use a sharp knife or jeweler's screwdriver to slide the lug from the watch
Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
