RCA DRC 290 does not support automatic play. It stops after playing 1 cd so u need to select at each play.
Please rate this.....
Hi, welcome to Fixya
This was extracted from the Manual of RCA DRC 290 (Click the link to see the complete manual)
To program the playback order of a
disc:
1. When playback is stopped, press
PROGRAM. The Program menu
appears.
2. Press the numeric input buttons to
enter the title and/or chapter
number (for DVD), folder and track
number (for mp3/wma or jpeg disc)
or track number (for VCD and
Audio CD). Press to move to
another input space.
3. Repeat step 2 as often as necessary.
4. Press to select “PLAY” and
then press OK. Items are played in
the order of the program list.
Playback stops once all items have
been played.
5. Press STOP to stop the program
playback.
• The program list remains until the
disc is removed from the player.
Press PROGRAM to review the
items in the program list during the
program playback.
Good Luck!!!!
As mentioned it plays them in sequence so if you load them the way you want to hear thm, that should accomplish your goal, good luck ,happy listening
What happens now when you have multiple CDs loaded and you press play?
You can use program playback and select all the tracks on all discks. It will play them in automode utill disk will be removed
1. press Program after playback stopped
2. Prees the number for disk and track number (you have to use all of them)
3. After selecting press play and OK
4. To cancel press Stop
Good Luck
Http://www.ehow.com/how_2012443_play-mode-durabrand.html
click the link directly and get full instructions
Steps for Intro PlayStep1Press the
"Repeat" button three times during the play. The "Intro"
symbol will flash on the display.Step2
Press the
"Play/Pause" button. The "Intro" symbol will stop flashing
and it will play the first 10 seconds of each track in the sequential order.Step3Select
the song of your choice during play and press the "Play/Pause"
button. The "Intro" symbol will disappear from the display by
pressing "Play/Pause" button. It will play the track selected and
will resume the normal play in the sequential order.Steps for Random PlayStep1Press the "Repeat" button four times,
during the play. The "Random" symbol will flash on the display by
pressing the "Repeat" button.Step2Press the
"Play/Pause" button. It will start playing the tracks selected by the
CD player in the random order and the "Random" button will stop
flashingStep3Press the "Skip"
button to skip to the next random song.Step4Press the "Stop"
button to change the "Random Play" mode
Hi
Repeat playback
During playback, press REPEAT
repeatedly to select a repeat playback
mode:
• For DVDs: Off, Chapter repeat, Title
repeat
• For CDs: All tracks repeat, Track
repeat
A-B repeat playback
1. To repeat a segment between two
points (A and B), press A-B at the
beginning of the segment you want
to repeat during playback.
2. Allow the disc to play to the end of
the segment or press FORWARD to
advance to the end point (B).
3. Press A-B at the end of the
segment. The segment plays
repeatedly.
4. Press A-B once more to resume the
normal playback
You can also view the manual for more details---
RCA DX290 User Manual
Check the manual here, there is no option for such a settings, however if many disks are loaded inside, they should be played automatically in sequence.
There is no repeat disk option, Check the manual here,
there is no option for such a settings, if disk are not played automatically in sequence, then this model does not have such an option.
If you select "Repeat All" disc in player menu that will enable player to playback all disc sequentially.
Normally player stops after playback of one disc. There is an option Repeat disc, Repeat All Disc, select repeat all disc.
U can opt for random play in the menu to let them play in sequence.
You will have to set it in that mode in the settings option.then only it will play.
Random Sequential Play Delete Play Intro Scan A-B Repeat .
Can you provide some more detail about what you're trying to do?
When you say "Automatically", what do you mean? In succession? Random shufffle?
According to the manual, there's a "Repeat" button on the remote control. Press this three times to repeat all tracks from all discs.
You can also press the "Random" button on the remote three times to play a random track from any disc, and play continuously until every track from every disc has been played.
The manual is here, should you need it:http://www.voxxsupport.com/images/manual...
I want the cd;s to play in succession.
I don't understand the solution. Can you be more specific?
I don't see a "succession" option in my General Setup Menu
My menu doesn't show "continuous play"
I have a " repeat all", but this simply repeats the disc which was playing.
I can't find a "Repeat all discs" option.
