I have a Thermador model PRG486GLUS all gas range. It was purchased and installed in June 2000. I have regretted opting for the grill instead of the griddle since day 1. Grilling indoors requires a very loud and fairly ineffective vent-a-hood. Plus, I have a decent outdoor grill. A few years ago, I asked Thermador directly if conversion from grill to griddle could be done and they answered, without elaboration, "NO". In looking at the exploded parts diagram for both models, the griddle assembly differs greatly from that of the grill. I can understand that a complete retrofit is probably not practical. However, I've wondered if I can find a griddle plate that would essentially replace or fit over the grill grate. Such a griddle plate would need to measure no more than 22" x 10 3/4". My existing grill burner is rated at 18,000 BTU compared to the griddle burner which is advertized at 15,000 BTU. Input on the assumed safety of this idea would be appreciated. Also, if safety isn't an issue, can anyone recommend where a suitable griddle plate can be obtained?
Http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
I would love to know if you can do this. I too wish that I had chosen the griddle. Please let me know what you find out!
