Question about Craftsman WeedWacker Gas Trimmer 29cc 4-Cycle Straight Shaft
Weedwacker overheats my weedwacker overheats changed carb
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
Air leak around crankshaft, scrap it and buy a new Stihl.
Posted on Jul 04, 2013
6ya staff
SOURCE:
Why does it keep running out of fuel?
needs new gas lines and carb,go to ebay and get them it is about 25 bucks,or you can rebuild the carb and buy a new line and fuel filter,ethanol kills weed eaters,use non ethanol gas from a marina
Jul 11, 2015 | Craftsman 27cc 2Cycle Full Crank Curved...
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Can't get weedwacker to pickup fuel to carb.
check the fuel filter on the end of the pickup pipe in the tank this was the problem on mine also blow the pipe through from the carb end back to the tank then should be ok
May 22, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
I have a craftmens 25 cc weedwacker thats about 3
it sounds like your carb is out of adjustment and you need to adjust it. Look at the carb on your weedwacker, there is an idle adjustment screw somewhere on it and using either phillips or strait screw head and then carefully turning it clockwise go 1/8 of a turn at a time until the engine idles smoothly.
Sep 05, 2009 | Craftsman Convertible 25cc. Gas Line...
The weedwacker dies when I squeeze the throttle trigger
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Weedwacker starts easy but will not run for more than 5 seconds .
May need to check for holes in fuels. Or fuel pump diapham is bad. If so replace carb., don,t waste money on carb. kit.
May 13, 2009 | Garden
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman WeedWacker Gas Trimmer 29cc 4-Cycle Straight Shaft Logo
178 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
