Question about 3Com U.S. Robotics Faxmodem 56K
U.S. Robotics Faxmodem 56K on Vista via RS-232
I want to run a U.S. Robotics Faxmodem 56K for general faxing on Vista but it is not reconnised by the Vista Fax utility. Is the problem likely to be the modem, Vista or the operator? :-)
Many thanks,
Julian
Located new Vista driver installed and worked, both driver and operator error.
Posted on Mar 20, 2009
Missing driver for PCI Serial controller device: PCI\VEN_12B9&DEV_1008&SUBSYS_00A212B9&REV_01
Try Device Doctor portable: http://www.devicedoctor.com/device-doctor-builds.php
or
SlimDrivers Free version: http://www.driverupdate.net/download.php
Mar 22, 2011 | Computers & Internet
My computer does not detect the modem
Well Some Faxmodem The Software as to be install first ... Check Make shure your Unit is On first and check the usb cable if is ok and connected correcly on the modem and on the PC.
Sep 22, 2010 | 3Com U.S. Robotics 56K USB Faxmodem...
I need fax/answering machine software for 56k us robotics modem
I would go to us robotics website and download the software and driveres for the modem.
Dec 12, 2009 | U.S. Robotics Modem: U.S.Robotics 56K V.92...
U.S ROBOTICS 56K VIA RS-232 FOR VISTA HOME
You can download the modem driver from US Robotics WEB site.
Use this link :-
www.usr.com/support/s-main-menu.asp
Aug 03, 2009 | 3Com U.S. Robotics Faxmodem 56K
U.S ROBOTICS 56K FAXMODEM DRIVER SOFTWARE REQUIRED(EXTERNAL MODEM
hi
here is the link
http://www.usr.com/support/product-template.asp?prod=5686e
May 20, 2009 | U.S. Robotics (USR5633A) Modem
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
Power supply for 3Com U.S. Robotics fax modem.
You need 9V/1A supply (with +9V at center pin) for your model with beige case. Do not use 22V/1.5A supply for old 33.6k model with
gray case. The shapes of the cases are very similar (56k has fever
leds, no external volume control, and no connectors for external
telephone equipment and external speaker), but the power supply
voltages and currents are completely different.
I hope this will help.
Dear sir,
I have purchase a U.S. Robotics 56K Fax Modem (USB) but when I installed in windows xp after modem driver installation some file could not setup properly then a message shown that continue anyway or cancel option. So that I need a fresh windows xp based U.S. Robotics 56K Fax Modem (USB) driver. My model no. is 5633. Please do something for us.
Thanking you,
Babu
Bangladesh Sericulture Research & Training Institute
Rajshahi-6207
Nov 21, 2007 | U.S. Robotics (USR5633A) Modem
3Com U.S. Robotics Faxmodem 56K Logo
376 people viewed this question
Top 3Com Computers & Internet Experts
john smith
didi2005
Mike
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
