This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Issue:
ERROR LCD: WAITING FOR REPORT Solution:
Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX
When
[AUTO PRINT RX] is set to [OFF], incoming received faxes will be
temporarily stored to memory and transaction reports (TX, RX and
Activity) remain in memory. The default setting is [ON], which means
incoming received faxes and transaction reports will automatically
print.
The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
Ink is low or has run out
The paper size and type is not set correctly
Paper has run out
The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
Press the <FAX> button to enter the Fax menu.
Press the <Menu> button. [FAX SETTINGS] is displayed
Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
Press the left arrow to select [ON], then press <OK>.
Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
CAUTION:
When this option is set ON, the fax machine will not monitor the ink
level of the ink cartridges. If ink is low or out, received faxes will
print with streaks or blank. Furthermore, once the fax is printed, it
will be deleted from memory.
To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
To
store received faxes in memory when ink is low or out, press the left
or right arrow to select [OFF] and then press <OK>.
Press the <Stop/Reset> repeatedly to return to Fax standby mode.
im not familiar with the particular model. A lot of the small brother laser fax machines will have the laser unit under the drum unit. if you take out the drum unit.. you should see a clear glass that goes across the width of the machine. it is about 1/2" X 9". There is probably toner and dust on the glass.
this will block the laser from reaching the drum. Clean the glass pretty good and this should at least help.
Incoming faxes automatically go into memory. We can't print them out. Would like incoming faxes to print out as they used to. have tried the on off button but it didn't fix the problem
