Lexmark 7100 series will receive faxes but wont send them
Lexmark 7100 series will receive but wont send them, phone line is ok dont understand what it is. One day it was working fine and the next it just started doing this.
Make sure your phone line for the fax is correctly plugged into the Line Port of the printer and not the EXT port. For a more comprehensive guide on how to setup the Lexmark X4270 for faxing, please refer to the Lexmark X4200 Series User's Guide.
The user's guide also contains some fax troubleshooting steps for your reference.
If you still need assistance, please contact Lexmark Technical Support Center.
Refer to the printer's User's Guide on how to connect your Lexmark X5470 to your telephone line for faxing. If the printer software is already installed on your computer, you can access the printer's User's Guide by going to the Start menu -> Programs -> Lexmark 5400 Series -> User's Guide (applicable to Windows OS). If not, you can download it from the Lexmark website for free using this link: Lexmark 5400 Series All-In-One User's Guide. Scroll to page 12 for the fax setup instructions. Also, check page 71for faxing instructions (sending, receiving, etc.). Hope this helps.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Yes your printer will send and receive faxes.
1. Make sure:
• The printer is connected to a computer that is equipped with a fax modem.
• The computer is connected to a working phone line.
• Both the printer and the computer are turned on.
2 Load an original document facedown on the scanner glass.
Here is the manual, in case you don't have one
http://www.retrevo.com/d/ds/progress?doc=7d2128cd89431b0e3d4c2a1c31fa8fc4
3 From the desktop, double-click the Imaging Studio icon.
4 Click Fax.
5 Click Scan and send a fax.
6 Click Preview Now.
7 Click and drag the dotted line box to select a specific area of the preview image to fax.
8 Adjust the settings as needed.
9 Click Next.
10 Follow the instructions on the computer screen to complete the task.
Receiving a fax using the software
1 Make sure:
2 From the desktop, double-click the Imaging Studio icon.
3 Click Fax.
it depends on what type of printer you have...i actually have an HP officejet j3500 series, it a fax, printer,scanner and copier in one.. when im using it for sending fax messages, i just dial the number where im sending it and it automatically faxes (phone keypad and handset is included)... and i use it as my printer too so its already connected to my pc..so easy to use...
but but but... i actually connected a separate phone line (our original phone from our provider) to the hp j3500 series cuz sometimes i need to speak first to thr person im sending fax before i send the message... i think that is for manual sending of fax...
so if you want to send manually (speaking first to the person before sending) a separate phone line is required (connected to ur fax)
but if u want autofax, then i dont think its necessary...
there u go...
visit this website to learn more.. hope this is useful
Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
Make sure that your recipient's fax machine is turned on and working.
If you connected the Epson Stylus CX to a DSL phone line, you must
install a DSL filter to the line or you won't be able to fax. Contact
your DSL provider for the necessary filter.
If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
Follow these steps to turn off the ECM setting:
Press Setup.
Select Fax Settings, then press OK. You see this screen:
Select Communication, then press OK.
Press and select ECM. Then press and set it to Off.
Press OK.
RECEIVING
Try the following if you can't receive a fax:
To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
Make sure paper is loaded.
Press Setup.
Select Communication then press OK.
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions
You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service
providers. Two phone numbers are assigned to one phone line so that
you will hear different ring patterns for incoming phone calls than for
incoming faxes. If you subscribe to this service, follow the
instructions below to program your All-In-One to use it. On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display. On the X63:
Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
Press Options until you see Learn, and then press Start/Yes.
Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
Press Setup.
Press Menu until you see Fax Receive Mode on the display.
Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
