My husband put my Onkyo TX-SV 727 on with out putting the volume down and because of that it went in protect mode. Can you PLEASE help me get the potect mode off so my Onkyo will work. Because right now it is not doing a thing. I did try holding video 1 and power to clear it and it didn't work. Also this Onkyo audio video control turner amplifer R1 TX-SV727 is no longer made
Thank you!
Roxie
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Thank you mmdesigns
