Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
hi, If its mac 1200 then try to check the battery and replace the same. here i have added the part number of the battery. Hi, Here is its part number 303 44270, 18V 1.4Ah nickel cadmium Battery ,
1.Press the setup Button
2.Select operating mode and press enter.
3. Repatedly perss the down arrow until it reaches to the "START AT QUEUE MARK" and perss enter. Then select NO and press enter ( if it is selected Yes then before each recording the recorder advance the paper to the beginning of the next page)
4. Press the Start button to exit the setup.
From the next EKG it will print from the first page.
ok
hi,
You have to change the battery of you ecg machine. Because even if the power is connected the ecg machine works on battery. If the battery is low the machine will go OFF after booting.
ok
Is the paper correct for the machine (look at old ECG's & check paper sensor black mark is in same place) also check paper is not in wrong way round or upside down?
Bob - www.woodenmen.co.uk
The heat on the print head can fade over time giving you a poor print. also the feed roller can wear and give poor pressure to the print head. thw way to diagnose it is to put a peice of electrical tape on the print roller and print an ekg. if it prints well in the area where the tape was, it is the print roller. if there is no change it is the print head.
[email protected].
www.overstockme.com.
Jeff Watson
