Not exactly sure of the question. You can charge any aircon by touch alone, just by feeling the return or suction side tube temperature. But generally you could also work on a 60psi backpressure.
The best solution is to have any refrigerant renmoved then the required amount put into the system by weight after the system has been tested for leaks or repaired. superheat charging if required can be done by
converting the suction pressure to temp then taking a temp reading at the tx valve. then by data colected calulate the superheat.
