I am getting the error (in title) and have searched the manual and online resources to identify where the waste cartridge is, and/or how to empty, but no luck.
SOURCE: message: waste cartridge is full or not installed
this is a common problem remove the waste toner tank and clean the sensor with air or crc precision clean see this http://www.fixyourownprinter.com/forums/laser/34677
SOURCE: message waste cartridge is empty / not installed at xerox 6100
For this machine I don't think there is a reset, but it is tempormental about the light that shines throught the back of waste cartridge.
Copy and paste this link directly into your address field, and see if you have it inserted correctly and then reboot.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=666,E=0000000000024654785,K=7760,Sxi=13,Solution=obj(20783)
Niallbt
SOURCE: replace waste cartridge on Xerox Phaser 7400
I just fixed mine. You need part #604K47890 Gear Coupling Assembly Kit. Cheapest I found was $6.99 at www.sparepartswarehouse.com plus $13.95 s/h. Remove the waste cartridge & you can see the white plastic gear. I tried to disassemble the printer (using service manual) in order to replace this part. Good luck. It looks like you need to take the WHOLE thing apart. Easier method is to get a drill or dremel & grind away the thin metal to make the whole slightly larger. Just be careful with the dust/particles. I did this & it worked perfectly.
SOURCE: Waste Cartridge Full
The optical sensor looks at a small compartment, that has clear walls; when the waste toner gradually fills the container, it eventually reaches the level above a "wall" between the main container and this small compartment, spills inside and makes not transparent anymore. Some toner might have gotten there and the sensor gives a false full signal. You can get rid of it by cleaning this compartment with compressed air.
Obviously, the sensor might be plain broken as well, but the above is perfectly true - it saves the day when the printer stops and we don't have a new waste container... I pour out the toner and clean the inside thoroughly with compressed air, especially that small look-through compartment.
SOURCE: I have a Xerox Phaser 7700dn that needed a new
well hope this helps if you need further assistance call item inc at 1-800-367-4836, they have good technician with good technical support and the best thing it's free !!!!
