Hi Susan,
I work in Tree Removal professionally so I think I can answer this one.
There are several methods you can use to prevent tree roots from sprouting after the tree has been removed:
- Cut the roots as close to the trunk as possible: This will remove the root's energy source and make it more difficult for the roots to regenerate.
- Use a root inhibitor: These chemicals are applied to the stump and can prevent new growth by disrupting the root cells' ability to regenerate.
- Remove the stump: If the tree stump is small enough, you can remove it entirely using a stump grinder or by digging it out manually.
- Cover the area with a thick layer of mulch: Mulch can help prevent light from reaching the roots, which can inhibit sprouting.
- Plant a new tree or ground cover in the area: This can help prevent roots from sprouting by providing competition for resources.
It's important to note that it may not be possible to completely prevent tree roots from sprouting after the tree has been removed. Some roots may regenerate even if you use these methods. It's always best to consult with a professional tree care service if you have concerns about tree roots on your property.
If you have any more questions, you can check out my page on Tree Removal on my website.
https://protreeworks.com.au/services/gold-coast-tree-removal/
