SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
SOURCE: i have a machine error 36 of brother dcp-115c help me
Machine error 36
**Head/carriage unit travel error***
Try to find any obstacles on the travel path of the head/carriage unit. If you cannot find, next steps are:
- Replace the carriage PCB.
- Replace the head/carriage unit.
- Replace the CR encoder strip.
- Replace the carriage motor.
- Replace the main PCB.
- Replace the power supply PCB.
- Replace the maintenance unit.
SOURCE: Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
SOURCE: my Brother DCP-150C cant print, displays, UNABLE TO CLEAN"
Unable to clean either means there's a paper scrap in the clean station, or the ink overflow box is full and needs to be changed by a dealer. Sorry, no quick fix...
SOURCE: unable to print 46
This is mainly due to dirty machine. Try following my steps:-
1. Press the Menu & Mono start keys. Next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. Press the mono start key several times untill the purge count appears on the LCD.
4. Enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero.
5. Press the stop/exit key to return to the initial stage of the maintanance mode.
6. Enter 9 twice by using the up arrow & set key's to exit from maintenance mode
