My LDS5811 seems to have steam coming out 4 small outlets at bottom of door that is causing it to condense and drip onto floor.
Does anyone know what I can do about this? Why is steam coming out there and where are the steam vented normally?
Steam coming out is not normal and you should get it serviced soon. While not dangerous, it probably means that water is leaking inside the door panel from the "Hybrid Drying System" that is a feature which LG uses/touts. Other disheashers use a conventional condensing drying system.
The moist air enters through the internal drying system in the door panel, dry air is added from the outside air with the help of a fan and that air is routed though ducting down to the bottom of the door.
That system is clearly broken. If you have more questions on this, please reply. Good luck!
