Power unit cooling fan is bad or jammed with dust!. looking at the rear of the machine on the right side lower there is a vent. remove the back panel (will require removing the upper back panel also. There is a filter with that motor. it mite be jammed in the fan clean it and tape it to the metal cover or just remove it then will have to check on every once in while. That fan cools the Power supply inside the machine. Might be burn it out worse case the control board that controls it is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
