Question about Homelite Garden
Motor will not start
Homelite AP 125 two stroke motor will not start fuel lines replaced and routed correct.
Spark plug replaced and has spark.
Fuel mixture 50:1 fresh batch.
choke and run switch all operating fine.
Fuel is in lines and primer bowl fuel is getting to cylinder also.
After trying to start for a minute or so fuel will run out of the carb.
Any ideas what may cause this and how to correct.
Thanks
  • dcnt1 Mar 19, 2009
    Thanks that did the trick...
  • 63 Answers
For some reason the engine is flooded. To make it start do the following: turn the choke off, hold the throttle wide open and crank it until it starts.Do not push the primer bulb first. It already has more fuel than it can burn. It will smoke more than usual until it burns out the excess fuel. You may also have a carb problem but this should allow the engine to start so it can be diagnosed.
Please rate this solution if it helps-
Posted on Mar 19, 2009
6ya staff
SOURCE:
I have a 1994 Yamaha 40 horsepower 2-stroke outboard motor turns over won't start doesn't seem like it's getting gas change the fuel line any other suggestions
Try removing a spark plug and make sure you are getting spark. If there is spark put a couple tablespoons of premixed fuel directly into the cylinder before putting the plug back in. It should fire right up, and hopefully will speed up the priming of the fuel system. Hope this is of some help to ya, good luck.
May 20, 2017 | Yamaha Boating
Homelite 26cc leaf blower got gas,spark,will not start with starting fluid
1 check your comprassion ratio on the cylinder , 2nd fuel hose broken or blocking the fuel 3th or fly whell key broken, start with new spark plug on 2 stroke engine 4th check for exhaust blokage 5th check the switch off and on for shortage, Fit fresh fuel,Check choke for floating the engine.
Jan 30, 2017 | Homelite Garden
The motor won't start
Older Homelite's love fresh fuel. Mix up a fresh batch of gas with the recommended oil ratio. Dump out the old gas into an approved container. Remove the spark plug for inspection and make sure that you are getting a good spark. If you are getting a good spark replace the plug and pour some fresh gas mixture in to the tank and follow the manufacturer's starting instructions. Generally they have a primer bulb press that in 5-6 times until it gets firm. Engage the choke and pull on the rope until it attempts to start. Turn the choke off and it should start right up.
If you did not have a spark on inspection replace the plug and repeat the process.
Nov 04, 2013 | Homelite Garden
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
BriMaxSmallEngineRepair
Gibbstown,NJ
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Not Starting at all and there is a spark
posible problem is the starting capacitor of the motor,,?? better replace it asap....
Sep 27, 2012 | Tools & Hardware - Others
Won't run at full speed continuously. Cycles speed up and down even at full throttle.
Check and make sure the exhaust outlet is totally open. If it has a metal gauze screen slide it out and wash with carby cleaner and replace.
Blocked exhausts are common problem in 2 stroke engines because users run the motor too slow and it ( + oily residue) carbons up the exhaust. With a blocked exhaust, usually the moror will start and idle pretty ok but will screw up when you try to run at full revs.
In Australia we get mud wasps building nests in there - a quick poke out of the mud and she's running full throttle again.
ps. Don't fiddle with the 2 mixture screws - unless your know what you are doing. You will only make it worse!!.
Nov 07, 2009 | Homelite Consumer Products Backpack...
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Homelite AP 125 two stroke motor will not start after replacing fuel lines. There is fuel coming into the carb and into the cylinder as well. Motor will not attempt to start. Spark plug is new and has...
If you have a two line fuel system make sure the lines didn't get crossed. If they are you could still get gas to the cylinder but not enough. I hope this will of some help to you. Donnyb60
Mar 18, 2009 | Homelite Garden
Replaced the fuel lines primary and return will not start now
You must go back over your new line replacements and see what you did to "starve fuel" first .Sounds like you have created a problem in new fuel lines
Mar 17, 2009 | Garden
Garden Logo
256 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
