Tonight, after setting the temperature on the stove, it reached the temperature and then it started a single short beep. I tried to stop the beeping by hitting cancel, but it wouldn't cancel. I disconnected the power from the wall socket, and waited 5 minutes, plugged the stove back in, and I was able to reset the time and reset the temperature and use the timer. After using the stove, I turned off the stove and about 1/2 later, the stove started beeping, short beeps, continuously. I pulled the plug again, waited 5 minutes, but this time, the display showed the previous time and continued flashing the time. Then after about 5 minutes of being plugged in, the "F1" display was shown and nothing could erase the display. The short beeping continued with showing the "F1".
Maytag Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
F0
Function key stuck
Replace touch pad or if touch pad is part of the clock, replace the clock
(ERC).
F1
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
Refer to F1 test at the top of this page for more information.
F2
Oven temperature too hot
Replace relay board, if present, or oven temperature sensor (RTD). Check
sensor harness.
F3
or
F4
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control.
Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
F7
Function key shorted or stuck
(ERC).
F8
Analog / Digital problem
F9
Door latch
Check door latch components.
F1 touch pad / ERC test
This simple test will
help determine whether the ERC (Electronic Range Control or Clock) or the
touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single
assembly, in which case this test is not necessary. Simply replace the ERC
(Clock).
Warning: If you feel in any way uncomfortable performing this test or
making this repair, please contact a qualified appliance repair
technician.
1. Disconnect power to the range (unplug the range power cord or turn the
power off to the range at the circuit breaker). It is very important that
the power to the range has been disconnected, so please double check
before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon
from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a
short when power is turned back on. Assemble the control panel back the
way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually
accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch
pad.
Hi
I tried typing in F1 into the search area, and nothing come up. How do I perform an F1 test?
Thanks so much.
Is this a job for an appliance specialist, or can I do it myself?
