I have a model 39a popcorn popper from Star. Gets hot too fast and burns popcorn if you are not right there. Could this be the High Limits parts kit? what parts woould I need to replace?
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
SOURCE: What is the Difference between A Star 39 and A
I was able to find out that the Start 39 popcorn makers are 6 oz capacity. The star 86 models are 8 oz capacity. I could not find a model labeled "Star 59"
Here is a link below to the manufacturer's website that should help you.
http://www.star-mfg.com/Scripts/Category.aspx?cat_id=11
Best Regards,
Mark
