THE TV WHILE IT IS ON, EMITS SMOKE AT THE BACK THE POWER IS OFF
SOURCE: tv projetion lg model rp-60sz30
You need a new bulb. It's easy to install. Remove the lower panel. Remove the 2 screws that hold the buld casing. Remove the bulb and replace with a new one. Replace the screws then the lower panel.
This will save you about $300 in so called labor.
SOURCE: No back-light on LG LED TV
That means dead transformer supply chain. Replacing search not possible, donor Yes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
