Dell PowerEdge R200 Server   Logo
Anonymous Posted on May 20, 2013
Dell server shutdown
We bypass the admin account because we didn't remember the password and made a new accound in administrators group. After that server was fine and worked perfect. But last days the server is shutdown after 20-50 minutes of powering on. What is going on? When it shuts down an orange light shows at power button. Pushing the power button and booting normal. In shutdown log there is no error
Anonymous
Level 3:
  • Dell Master 2,878 Answers
  • Posted on May 20, 2013
Anonymous
Dell Master
Level 3:
Answers
2878
Questions
0
Helped
487386
Points
8243
Try using OMSA, which is Dell's Server Administrator. Specifically for hardware and errors.
https://servername:1311 You require a local admin or domain account to login.
2 Related Answers
Anonymous
  • 7 Answers
  • Posted on Mar 17, 2008
SOURCE: dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Anonymous
  • 108 Answers
  • Posted on Oct 24, 2008
SOURCE: help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
1helpful
2answers
Bypassing the main admin page password lock on my dell d620 laptop with windows vista when wsnt given the pw so i cant get in it. Thats my question im stumped?
op why not tell the full story
I just bought a used vista laptop and...
or kids played with my long used laptop .and..... (ask them?)
or what?
for sure what is locked you have not stated.(no photos of screen)
boot pw
bios pw
hdd password, (impossible to crack)
or vista login password (easy)
4 different answers
here are ways to learn and find answers.
1: ask Dell.com first. we are NOT THEM.
2: google all day. see up to 7 radicall ways to cure it and not one works, (a fact)
3: youtube it, make sure its your D620 model they are talking about or it will not work.
4: https://pcdied.com/passwords.html
tip
How to enable Windows 7 administrator account and reset lost Win 7 admin...
How to enable Windows 7 administrator account and reset lost Win 7 admin password
There are two parts for your Windows 7:
* Enable Windows 7 administrator account
* Reset lost Win 7 admin password
With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods.
Part I: Enable Windows 7 administrator account
Method 1: Use Command Prompt
The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt.
1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator.
2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear.
3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled.
4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account.
Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps:
1. Switch to log on Windows 7 with the administrator account.
2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account.
3. Click Create a password for your account on the screen.
4. In the coming screen, type and confirm your Win 7 admin password.
5. Enter password hint and click Create Password.
Now your Windows 7 admin password is successfully created.
Method 2: Use Local Users and Groups
1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up.
2. Double-click the Users folder. And all the Windows 7 account will be displayed for you.
3. Right-click the Administrator account and select Properties.
4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen.
Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below:
1. Right-click the Administrator account and select Set Password.
2. Click Proceed to go on your operation
3. Type and confirm your new Win 7 admin password and click Ok
4. Close the Local Users and Groups screen.
Now the Windows 7 administrator password is assigned to your Windows 7 admin account.
Part II: Reset lost Win 7 admin password
Windows 7 administrator password reset Tips:
Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows.
Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password.
step 1. Download and install Windows Password Breaker.
step 2. Run the program and burn a Windows password reset disk.
Step 3. Reset Windows 7 administrator password with the disk.
It is an easy and safe way for Windows 7 admin password reset.
on Nov 02, 2010 • Computers & Internet
4helpful
4answers
My dell studio is having major problems, i lost the windows on the laptop itself and reverted back to using a disc of mine. Now when i've come to restore the laptop I can not use the wifi at all or...
Since you have reinstalled your Operating System, you will have to reinstall all the drivers for your devices and other functionality to work properly.
The best way to obtain the correct drivers for your new Operating System is to download them directly from the manufacturer's support website.
Go to the Dell Support website > Drivers & Downloads page.
Here is the direct link for your Dell Studio Laptop 1749 : Drivers & Downloads for Dell Studio Laptop 1749.
Select your Operating System and you will be able to download the correct drivers.
Hope this helps you.
4answers
Administrator password locked askesforwindowsrepair disk will gothrogh program then says has no hard drive can i reset harddrive or password dont havepassword windowswillnot display
You can recover windows password with windows password recovery tool. I know a tool named "windows login recovery" that can remove windows password without losing any data and you needn't reinstall windows OS. Download it from http://www.windowsloginrecovery.com and burn the program to a blank CD or a usb flash drive, insert the CD into the problem computer and reset your password to “Blank”. By the way, it is also useful to recover administrator password.
6helpful
5answers
10answers
Forgot password
pls a lil' clarification here is it bios password u forgot or windows password?
2answers
How can I bypass password in XP Pro for Dell GX280
log on through your ID
and click on Start
right click on my computer
click on Manage
one you see computer management pane
expan Local user and groups
select User
now double click on Administrator
then check mark on Account is desabled.
or just you can delete to Admin
and restart your computer.
Remember: before you disabled your Admin user get yourself admin rights.
thanks
1helpful
4answers
I just purchased an ee pc and i changed my password now i cant remember it and cant get the system on withoutit
You need to get the password reset from the company itself and its free
Contact:
In order to increase the efficiency of your call, ASUS technical support recommends that you fill out a Case Submittal Form before you call our support center.
510-739-3777 or 812-282-ASUS (2787) - option 3; option 3
FAX: 812-284-0883
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
