My HP cp1700 printer display panel is partly blurred, I got to the panel but what is the reason for blurring ? The cables the panel itself or what ? What can I do to fixit myself?
Is it the print coming out ok or blorred go to hp website and download drivers and software plus contact them for assistance on your printer.
hope this has helped
A blurred screen on the right-hand side of a Blaupunkt TV for about 2 inches from top to bottom can be caused by a few different issues, such as:
A problem with the display panel: The display panel may have become damaged or malfunctioned, causing the blur on the right-hand side of the screen.
A problem with the T-CON board: The T-CON board controls the video signal between the main board and the display panel. If it is not working properly, it can cause the blur on the right-hand side of the screen.
A problem with the main board: The main board controls the various functions of the TV. If it is not working properly, it can cause the blur on the right-hand side of the screen.
A problem with the cable or connector: Damaged or loose cable or connector can cause the blur on the right-hand side of the screen.
It's best to consult the manual or a professional technician for help. They will be able to diagnose the problem and recommend the appropriate course of action. Sometimes, the problem can be solved by replacing a faulty module, repairing or replacing damaged cable or connector, but in some cases the repair may be more complex and require more extensive work.
When you double click the Printer and Faxes icon in the Control Panel
you will see the printer that your computer is currently using. See....
if the printer image is clear it is online and ready to use, if its
blurred then its in offline mode and cannot be use.
To correct
offline printer.. some possible reasons is on the usb cable.. check if
there is no open wire along the cable...Inserting the USB connector on
the other usb slot of the cpu sometimes work just wait first until it
is read.
If the printer is still blurred and offline after
checking the usb connection, the 2nd thing to do is check the
properties of the printer if it is set to offline mode. how? Double
click your printer icon. It will display the print jobs window. Click
on the Printer tab and uncheck on the "Use printer Offline". Cancel all
pending print jobs, close the printer window and try again to print.
This is problem many of hp cp1700 printers. LCD display have manufacter issuse. After some time degrage material joins LCD with controler. You can partial fix this issue, but you must take to parts front panel and repair cable contact on both side of plastic flat wire (one side plastic flat wire and LCD, two side plastic flat and LCD controler board ). Repair must be done with stress dull tip and hot temperature, may use tinfioil and soldering iron. OR you can bay new part panel board with lcd aproximaly 150$. OR you do not repair printer and use pc program that view display info form printer display on pc monitor. On Linux I use HPLIP Toolbox.
Unless you're running at the display's native resolution (check the box or product literature, for your laptop probably 1280x800) you will have some blurring on photographs and other parts of the display. You will need to set your resolution to 1280x800 to see crisp photos.
To change the resolution in Vista:
1.
Open Display Settings by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2.
Under Resolution, move the slider to the resolution you want, and then click Apply.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
I have the same problem almost all letters are gone, I have an error now and dont know what kind of error it is, can you help?
Thanks from Norway
