Codec6102
C6102: Drive Home Sensor malfunction
1.Correct or change the Scanner drive
(cable, pulley, gear, belt) if it is faulty.
2.Correct the Scanner Motor set screw if
loose.
3.Adjust [Image Position Leading Edge] and
[Feed Direction Adjustment].
4.Check the PC201, M201, PWB-IC and
PWB-C connector for proper connection
and correct as necessary.
if all that doesnt work Change PWB-IC.
