When i go to print the labels, it isn't centering the info so it is therefore, cutting off the info and I can't figure out a way to get it centered.
Try going into printers and faxes and right click on the label printer and going to properties.
There should be a tab in there for size for you to specify the size of the labels or to manually type in the correct size.
You didn't tell us if this was a new problem on a label printer that had previously printed correctly or not. If it just started, then the driver for that device could be damaged and a reinstallation of the driver might solve the problem.
