Casio Pathfinder PAG60-1AV Watch Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pin on the watchband is protruding
The band is not broken but the mounting pin close to the watch face is sticking out and won't reseat when I push it in. It appears that the casing hole (where the pin is) might be slightly worn and elongated. Must I purchase a whole new watchband or is there a 'fix' for what I have?
Chuck
Sid
Level 3:
  • Master 483 Answers
  • Posted on Mar 18, 2009
Sid
Master
Level 3:
Answers
483
Questions
Helped
191499
Points
1547
No need to buy a new watchband friend, you need a new pin. The spring inside the pin has lost its elasticity ... you won't spend a fortune ....
Please rate the resolution.
I have a new Stauer Blue Stone chronograph watch. I need the stainless watchband shortened by 3 links. It has on 6 links a arrow pointing down. How does it work?
The arrows show which way the connecting pin comes out. You need a pin press. Take it to a local jeweller.
https://www.amazon.ca/Watch-Band-Tool-Kit-Grey/dp/B087N7FGZJ/ref=asc_df_B087N7FGZJ/?
Flip the watch band over and check the underside. Links that can be removed will have an arrow etched on them. The arrow's direction indicates which way to push the pin to slide it out of the link.
Watch Bracelet Link Removal Tool - Stauer
Remove watchband from citizen black eagle watch
they will be pins like the ones in this video you will need to push them out with a punch the size of the hole,normal watch bands are spring loaded bars.
Jan 19, 2013 • Watches
1helpful
2answers
Trying to change leather watch band. This watch has a narrow space to attach rather than a wide space. Have tried to push pins and they will not move.
The easiest way to insert and remove watch band pins is with a band tool. This small tool has a very small, thin fork on one side, usually made of tempered or hardened steel, that you use to spear one end of the watch pin; you can then quickly and easily apply the leverage needed to pull one end out of its mounting hole. Many watch pins have a small collar at each end designed to catch this forked end. These inexpensive tools are sold at most jewelry supply houses or come as part of a "watch maintenance kit" that can be purchased online or at Harbor Freight. However, you can also solve your problem without this tool.
There are two approaches to removing stubborn band pins without the right wrench. First, you can use a sharp knife blade (a screwdriver blade won't work) to try to grab the end of one of the pin to try to pull it out of its mounting hole. Band pins without collars are usually designed to pull a bit more easily from one side than from the other; if you're not having any success on one side of a pin, try the other. In addition, you might want to wear leather gloves--using this procedure, it's almost certain that the knife blade will slip out of control at least once or twice, and there's a serious risk of accidentally cutting yourself unless your hands are protected. Further, you may gouge a notch in your knife blade, damaging its smooth edge. Still, if you need to preserve the band pins, this is a common way to go. Finally, if you put too much pressure on the mounting hole in a plastic watch case, you run the risk of tearing out the hole. In that case, the watch is now useless as a wristwatch, because you can't attach a new band to it.
On the other hand, if your replacement watch band comes with replacement pins, you don't need the watch pins that are currently mounted in your watch. If that's the case, use a pair of nipper pliers to cut the pin in half. You can either push the old band out of the way, or you can even cut it off to get better access to the pins. If you cut the pin approximately in the center, it should be easy to pull each half out. Conversely, if you cut the pin very close to one edge, you may have a bit of a challenge pulling the short end out--but it's still quite do-able.
I always change out the band pins when I change a wristwatch band, so I have become increasingly fond of cutting the old pins in half and pulling them out if I can't easily get them out with a band tool. Doing so minimizes the risk that I will damage the pin mounting holes in the case. Even in a metal case, elongated mounting holes will not hold a pin as securely, making it easier for the band to spring out and the watch to fall and get damaged.
How do I get the pins holding watchband off? I'm
With some practice you can get them out without damaging them.
With one finger press the pin upwards and use a small screw driver and gently press the pin toward the center.
Relax the finger pressure while pushing with the screwdriver and then return the pressure as you stop pushing with the screwdriver.
Some skill is required but you should be able to remove the pins after a few attempts.
Putting the pins back in by reversing the process (i.e. put one end in and press the pin gently onto the watch; push the spring loaded pin in while pressing it against the case and when the pin is far enough in, it will slide down the inner face into the hole.
Its easy! (after some practice!).
2helpful
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • 2helpful
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Buy and replace new watch band ?
    I just replaced the band on a women's ironman watch, so I know it is tricky, but can be done. First remove the old band using a small flat blade screwdriver and determine that the spring bars that came with the new band are the right size by comparing with the old ones. My new ones were too large. Then, use a pen to make marks on the back of the watch case in alignment with the spring pin holes . Put a spring pin into the band and position the band on the watch the way it will be attached, with the pin just above the marks. Use the small flat blade screwdriver to insert one of the spring bars into its hole and align the other side of the spring bar with its mark on the case. Compress the spring bar and slide it down until it roughly aligns with its hole, then, push the band sideways toward the hole and wiggle the band until the pin seats. Apparently the hole alignment is very tight and, without that last step, the pin simply will not seat. After spending a lot of time with the first strap, locating the spring pin hole by trial and error, I used a magnifying light for the second strap to allow me to see the spring bar hole, making the process a lot faster.
    10helpful
    HOW DO I TAKE A LINK OUT OF THE WATCH BAND
    Start by looking at the inside of the watchband, there should be a arrow pointing up/down. Take a pin and put it in on the side that shows the arrow going down. Take a hammer and GENTLY tapp the pin. The pin should push out a pin in the band. Do this as many times as you have to for the size you desire, and then put the pin in the same derection as you tapped the pin out. Usually you will also see a **** on the side youn DON'T want to tap out. If you still; have a problem don;'t hesitate to write me, and I will be glad to take you step by step with this. Good Luck!!
    332helpful
    18answers
    Remove links from metal watch band
    This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
    I used a neoprene mouse mat as a work surface, which was ideal as it allows the pin to move out, whilst supporting the links and stopping any slippage. I also rigged a table lamp close by.
    There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
    As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
    Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
    9helpful
    3answers
    Shorten watchband
    I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
    Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
    It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
    Top Casio Watches Experts
    k24674
    Robert
    ZJ Limited
    ZJ Limited
    Are you a Casio Watch Expert? Answer questions, earn points and help others
