Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFL49X Fridge compartment
When the fridge is cooling the fan starts to make a noise which has been gradually getting louder over the past few days. Now unbearable to listen to. The 1st year warranty has typically just expired, but we not even used over that full time period. 10 months use. I can't see any visible forms if ice build up, so assume the frost free function is ok. There no flashing warning lights on the display and the temperature is set to 5 degrees C for the fridge. Apart from the noise is OK, but expecting a motor to burn out soon?
  • 1 more comment
  • kev_w Aug 22, 2007
    Just needed a manual defrost.....
    Ice still builds up over time around the fan so contact and noise will eventually be made.
  • Anonymous Apr 25, 2008
    My landlady bought a used Hotpoint for my apartment. Model CTX14CYBBRNW. Make a horrible noise when every 15 minutes or so. Possible cause?
GE Hotpoint has a history of bad fans and poor customer service. Unfortunate and a costly defect. Repair this yearly, forever or trash and buy new???
Posted on Aug 22, 2007
Kenmore elite french door refrigerator and freezer not cooling
Check the compressor start device. The fans will be running and the compressor fan will be running but the compressor is problaly not running. If it is then it could be the compressor itself that is not oumping.
Mar 25, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Food in bottom compartment freezing food
you have the air flow regulator in the bottom of the fridge close to bottom compartment wide open experiment by closing it gradually till you have the desired result.
Sep 18, 2009 | GE Hotpoint Top-Freezer Refrigerator
RLA Future Hotpoint Fridge
This may be caused by a fanmotor touching something, or one of the copper tubes from the compressor causing a resonant frequency. If you touch the different tubes to find out which one is causing the noise and then slightly bend it with your fingers. That should stop the noise.
Mar 13, 2009 | Hotpoint RLA30 Compact Refrigerator
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
376 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
