See if this works for you.
Remote Operation
When you are away from home, you can operate your answering system with any
touch-tone telephone.Use this function to check for recorded messages, to play or
delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code.
3) The answering system announces the current time and the number of messages
stored in memory. Then you hear "To play incoming message, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command
from the following chart:
Command Function
0 then 1 Repeat a Message
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message
0 then 5 Stop Operation
0 then 6 Answering System On
0 then 7 Memo Record/Stop*
0 then 8 Greeting Message Record/Stop*
0 then 9 Answering System Off
1 then 0 Voice Prompts
If you forgot to turn on answering system the directions for that are here:
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely
from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the
number of messages stored in memory. You hear "To play incoming message,
press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system On. You hear the outgoing message
and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
