Won't empty water and made two error codes. ld and ob.
Ld
Long drain
"Ld" flashes if it takes longer than 5 minutes to pump out water to a
point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
ob
Off balance
If the motor controller detects an unrecoverable off-balance condition,
the machine controller will shut down and display an "ob" for off balance.
The lid switch must be opened at least once before restarting the cycle,
if this condition occurs. Opening the lid will allow you to view and
redistribute the load.
washer gets stuck in rinse cycle and wont drain water
keep getting error code FL
fl code beeps 10 seconds spins 30 seconds but doesn't drain... help
