Praktica DC42 Digital Camera Logo
Posted on Mar 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak C330 digital camera won't recognize any memory cards
My Kodak C330 digital camera no longer recognizes the memory cards I insert into it. The problem began when it stopped recognizing a 128MB card that used to work perfectly with the camera. I tried formatting the card, but the problem persisted. I tried buying and inserting new SD cards, always Kodak brand, and always formatting them, but the camera doesn't recognize any of them. I realize that this camera is too old to accept 2GB cards, so I haven't tried those. The largest memory card I've used is 512MB.
  • Anonymous May 15, 2009
    dscdsc
Anonymous
Level 3:
  • Master 1,234 Answers
  • Posted on Aug 27, 2010
Anonymous
Master
Level 3:
Answers
1234
Questions
0
Helped
294094
Points
1672
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Add Your Answer
    2answers
    I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
    This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
    Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
    I have a Kodak C330. The memory card reads full
    Having gone over a month without a response, I assume this is no longer a problem.
    1helpful
    Refurbished digital cameras c330 and c315 are not reading Koday memory cards
    C330 and C315 its compatible Only in 1GB SD card or maximum 2GB SD card. More than this it cant be recognized by the camera or to reformat it.
    If your card is 1GB SD card still its now working it means the memory card slot of the camera is defective.
    3helpful
    2answers
    Memory card
    I experienced the same problem with my Kodak C330. I took it to Walgreens and the tech stated that the C330 was created before 2 GB memory cards were invented; therefore, the software inside it doesn't recognize a larger GB capacity. In short, the C330 has a 1GB max capacity. Considering you can take 1200 pictures with a 1GB card, a larger size really isn't necessary.
    Memory cards wont format, says card is full
    Is the write protection enabled on the cards?
    Which size having the cards?
    The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
    Click
    But try an firmware upgrade.
    Why download firmware version 1.07?
    This firmware version improves memory card compatibility and provides general performance updates.
    KODAK EASYSHARE C330 Zoom Digital Camera Firmwar
    Memory card is in camera(kodak c613) Camera
    Make sure the card is fully pushed in; otherwise it could be the reader.
    You could try to insert the card into an external card reader connected to a PC.
    If it is recognized by windows, click "format".
    If that works put the card back into the camera.
    If it is now recognized, go to "menu" and format again with the camera.
    If the card is not recognized, your internal card reader seems to be faulty.
    Hello i have the kodak easyshare c330 digital camera . i just purchase a kodak sd 2gb memory card the camera is stateing that the memory card is full can you help me with this problem please
    Click
    But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
    KODAK EASYSHARE C330 Zoom Digital Camera Firmware
    3helpful
    New memory card says memory card full
    The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
    Top Praktica Cameras Experts
    ZJ Limited
    ZJ Limited
    Ngoro
    Are you a Praktica Camera Expert? Answer questions, earn points and help others
