I have fios tv..dvd is a mitsubushi DD 430..19" magnovox tv.flat screen.surround sound works find when in fios tv mode,but when in DVD mode..unable to hear surround sound??surround sound works find when in fios tv mode?? How should I connect my DVD in order to get surround sound?? Thank You for your time..
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
In that case, it's likely that your DVD player has the audio output set to something other than what you've got it hooked up as.
Go into the "Menu" of the DVD player, and look for Audio or Sound options.
When you find that, see if there's a way to change from Digital (or Optical, possibly) to Analog. That should do the trick.
If there's nothing hooked up to the surround sound receiver, that's normal, since you're connecting the DVD player directly to your television.
It simply sounds like you've got it hooked up wrong, not that there's anything wrong with it.
Disconnect everything, and then plug in the red, white and yellow cables from your DVD player, to the television. That should do the trick.
Can you try connecting the DVD player to another tv? Maybe the inputs on the TV are no good.
If that doesn't work, and there's no audio on another TV, it's likely that the output on the DVD player isn't working anymore.
thanks for responding to my question..DVD is hooked up directly to television..
I went into menu for dvd..there wasn't an option for converting from digital to analog..Please note , there is a connection on surround sound receiver for the dvd , but there's nothing plugged in dvd terminal??Shouldn't something be plugged into dvd terminal on receiver?? Thanks..
no that did not do the trick..but thinks anyway..
