Nintendo Game Boy Advance Console Logo
Posted on Mar 18, 2009
I try to update my psp and this error drffffffd7 appears
Psp;
update
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Mar 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6935
Points
21
Your psp is on custom firmware if you got this error code. Simply put it will not update with official updates given out be sony. If you wish to update it, you have to go to Dark-Alex's page and download the custom firmware version you want.
  • Anonymous Mar 18, 2009
    I forgot to add his page.
    http://dark-alex.org/
2answers
How can i downgrade my ver 6.10 software psp????
Hello there
Download MPH Downgrader and Firmware version you want(e.g 1.50) to the Windows-based computer. Connect the PSP Slim to the computer's USB port using the USB connector. Transfer the two programs to the main folder of the PSP Slim. Disconnect the PSP Slim from the computer's USB hub when the transfer is complete.
Turn on the PSP Slim. Go to the Settings/USB Connection in the Home menu and select the EBOOT.PBP file in the PSP\GAME\UPDATE update folder. Extract the MPH Downgrader zip file to the root folder of the PSP. Click OK using the X button if you are prompted that this will replace some files.
Go to Photo/Memory Stick in the Home menu. Wait as the screen goes black and numbers appear. Wait two minutes and then press and hold the power switch until the PSP Slim turns off. Release the power switch.
Wait as the PSP Slim turns on and reboots. Go to Game/Memory Stick in the Home menu and select PSPS Update version 1.50. Press the X button to start the update.
Wait as the update finishes and presents an error message. Press the O button to restart the PSP.
2answers
PSP Update Error
ok i got it your system configuration is incorrect just do that go to system setting and check out the configuration setting carefully and it will be done.
1helpful
Psp update problem
DNS error 80410414 means the web address was typed in wrong eg: i tryed every thing when this mesg came up, then when i nearly gave up i typed www.facebook.co.uk and it changes the address to http://en-gb.facebook.com/ the psp cant do this so it just gives an error mesg
i then typed in the address on my psp the exact address; http://en-gb.facebook.com/ AND IT WORKS :) WOWO :)
rate it if the problem resolves
9helpful
2answers
My psp wont update it says error 80010005
when I try to install a game it says failed the Update Contact Technical Support for assistance can anyone help me?
Sony psp version update
Try updating it manully by going under settings then software update. you need WI-FI though but it is worth it
4helpful
System configuration error (DRNFFFFFFCD) 5.50
You need to fix IDStorage... Google for Despertar del Cementrio 8 fixing idstorage
Psp error(DNRFFFFFFD7)cant get update.
try downloading update on computer. then take eboot file and put it on your mem stick in the x:psp/game folder then run the game if this doesn't work i can reflash an original firm ware for you for5$ plus shipping email me [email protected]
6helpful
7answers
PSP Update Error
I have had the same problem and i fixed it!! the way i did it is I used (key cleaner). this program basically cleans bad keys. These bad keys are causing the problem. The version to download is 1.4. Also i have the thick PSP.
This is the website
http://forums.maxconsole.net/showthread.php?t=56265
7helpful
14answers
WIFI does not work: internal error 00000001
dont worry its no problen sony did not encode the higher versions it should say no network found but but it is the same thing so dont worry
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
