Hello and HELP! We are a very small business and our Xerox Phaser 3200 MFP has the error code: LSU. The machine was working fine, the toner was low so we changed the cratidge and now we got the LSU error code. HELP!
I had the same problem,it's from the photo cylinder it's not the laser unit. Just replace the cylinder or the cartridge.I had the same problem,it's from the photo cylinder it's not the laser unit. Just replace the cylinder or the cartridge.
You can't post conmments that contain an email address.
This option does not need to be changed unless you are getting a overheat error. If you lower the heat on the fuser this can result in image transfer on the paper leaving blotches and ruining the fuser.
Hello, on your toner cartridge there is a slot for a chip. Usualy the chip needs to be replaced on eache refil. In your case you will need a chip for the toner cartridge so that your machine can continue to work.
I'm not sure what the problem is or what machine you are using but follow the link below and enter the name of your machine and then the error message and it should help!
Try downloading and installing a PCL language driver from the Xerox.com site for the phaser 3200. It looks like that could be a PostScript issue. Installing the right driver is very important anyway. If that does not help, try and copy paste the document in a new document and save first as the old document could be corrupted. If this does not help either lemme know and I think of something else.
