I have a emachinew3050 computer,I use windows XP home edition,I have internet explorer 7.When I go to any web site it changes the background to white and I do not see all of the images.thought it was explorer was mess up so I downloaded Foxfire to fix and it does the same thing.I went to control pane4l to internet options and display and both say it should work correctly but it does not.Check the same sites from another computer and that is how I know they are wrong.I have tried to fix this issue till I am so frustrated I have no clue at this point I am ready to reformat this thing.please help before I lose all my stuff on my computer from a reformat. Thank you in advance for any help LynnB44
Are you able to get a screen capture of the websites you are viewing that look messed up?
It could possibly be a malware infection. Try scanning your system with Malware Bytes.
http://www.malwarebytes.org/mbam.php
regards,
Cam
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper".
In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background.
The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes.
hope this helps
