http://terraofficesolutions.com/forum/index.php?topic=27.0
Quoting from web page shown:
Ricoh Error Code 322, SC322 Fix - Printer, Copier, Fax Machine
on: October 01, 2012, 07:40:17 pm »
The Ricoh copier error code SC322 or 322 is a laser synchronization problem.
This error code can mean:
Bad LDB
Bad IPU Board
Bad Controller Board
Bad Detector Board
Check the wires between I/F and Detector.
After the polygon motor reaches standard rotation speed and the LD unit fires for 400 ms, the laser synchronization detector does not get a signal.
• wires between detector and I/F disconnected or bad
• Detector is installed incorrectly
• Detector board is bad
• IPU board bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
