My oven temp seems to be off. I changed the glow coil in the bottom because the oven would not work. Now it seems to be cooking at a hotter temperature than it is set at. Can i calibrate the oven temp?
Does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
My oven is a wall built in oven that bakes unevenly, is the calibration off or is it something else
my oven is set 350 degrees and it reading 299 degree how do i calabrate this or who do i call
