I purchased this tape player but sure could use some help on operation
and the proper way to feed the tape from reel to reel.
any information would help me .
Thanks for your support
Dave
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
Almost all can be played on any reel to reel player, some reel to reels were used on really old computers and I am not sure about those. Hope this helps
Try to turn the wheel manually and see if it turns properly. There must be a belt or gear assembly which turns both reels simultaneously. If its a belt, check to see if its broken.
When facing the deck, the feed reel goes on the left and the take-up reel goes on the right. Make sure to secure each reel by engaging the reel locks on each of the spindles. Place the feed reel with the free end of the tape on the left and hanging downwards (like the letter "P"). Pass the tape to the right of the tension spindle (which is above and to the left of the play/record heads unit. Pull the tape down and pass it underneath the heads from left to right. Then on the right hand side of the heads unit pass the tape between the guide wheel and the first guide spindle to its left and just above. Then pass the tape over the top of the second guide spindle. Finally, loop the tape under the right hand tension spindle and pull it up and feed onto the take-up reel from the right in an anticlockwise direction (like the letter "g"). Once you have it through the slot in the centre of the reel, hold the tape end there with your finger and wind the reel around a few times to hold the tape in place and ... Voila!
Jazzie: Your pinch rollers are worn. Put in a new set and probably a drive belt while you're at it and you'll be back in business. When the rollers are worn and tapered, the tape just rolls right off. Be sure to get the Pioneer replacements! Part---- RXB-325
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Sounds like the take-up reel isn't turning. Often the linkage for the take-up reel is used for both Play and Fast Forward. So test the Fast Forward.
I would look for a broken belt or slipping drive wheel. The fact that the tapes are unraveling tells me that the capstan is pulling the tape out of the feed reel.
Yes you need to hook it up to an amplifier and speakers through RCA cable on the back. And or you can use headphones if there is a headphone jack? Also make sure there is something recorded on the reel tape in the first place. You can do a test recording of something like a CD from your CD player or record something, then play it back, make sure you turn the record input volume knob up and make the RCA connections on the back of the reel unit and connect to your playback source you want to record. When you playback the reel tape, the db meters should be moving on the front of the reel deck, if they move then you most likely have some sound recorded on the reel tape. If you still can't hear any sound and the db meters are moving, then check all your connections again and volume output knob on the reel deck. Hope this helps?
