How to turn wireless WiFi on/off Windows 7, 8, 8.1, & 10
Description
This article describes how to turn the WiFi radio on or off. Follow the provided instructions to enable the wireless card.
There are several ways to turn the wireless radio on or off.
There is usually only 1 way to turn on wireless especially if it is switch. Maybe you can use a small screw driver and turn it on but be gentle since its very fragile. Sorry for bad new. Good luck.
First, turn the wireless switch OFF and switch it back ON
(make sure sure that there is a BLUE light on the wireless indicator)
then press Fn+F5 (this will ENABLE the wireless capability of your computer)
>Try to detect wireless networks
>comments suggestions ratings and violent reactions will greatly be appreciated
Most desktop computers are not by default wifi capable (barring a few models that include an internal USB wifi adapter in the case.) If you have added wifi to the unit by installing an internal PCI-Card Wifi adapter or plugged in a USB Wifi adapter into one of your USB ports then that capability will be added. As far as a Keyboard command to activate the Wifi, that is usually dependent on the Computer and/or the brand and model of the adapter installed. What brand of Computer and model are you having problems with? If the Wifi was added after it was purchased, what brand and model of adapter are you using?
If you were using Desktop PCs, then usually you need to install a WiFi Card to make it WiFi Capable (its like a LAN Card but with Antenna, or you can simply purchase a USB WiFi device if you dont want to open your Computer. if you were use a Laptop check for WiFi setting or switch on your Laptop and turn it on, make sure your WiFi driver is installed properly.
