I have 40'' LCD flat panel about 1 1/2 yrs old and about week ago it became harder to power on after hitting remote or power button on tv. Today it makes a clicking noise and will not come on. Is it a power supply issue?
It is a power supply issue. options 1- replace the power supply
2- this unit has an issue with 4 capsitors on the power supply which sit side by side and are about 10 volt each replace them with standard 16v caps.
Definitely a power supply problem.I had the same problem and changed the power supply, and TV works normally. Depending where you buy the unit, it shouls cost around $150/--, and it is very easy to replace.
Hi Friends,
I had the same problem with a 46" Samsung LED. There was continuous clicking of the relay and the red led also flashing non stop.' Power on 5V' line in the main board was short with ground. Replacing the main board solved the problem. I hope this will be helpful.
Is this something the average person can replace himself or does it require a repair person?
same problem here. i see the led blink 4 times then i hear the clicking, but the tv will not start.
Same problem here. The set is about 2 years old. It just keeps on clicking and trying to come on, but doesn't.
1 HAVE GOT THE SAME PROBLEM, THE TV IS ABOUT 2 YEARS OLD.RED LIGHT BLINKS BUT TV DOES NOT COME ON.
I have the same problem. Just started this week. How much to fix?
I have the same problem... tv is 15 months old
