For my Sony BRAVIA KDL 32S5100 I turned on my TV and it says no signal in bottom left corner and the screen is blue. I have everything hooked up through my Sony Home Theater STR-KS360. Home Theater is hooke dup to hdmi1 and I get sound but no picture. Same for the other 2 hdmi ports. When I hook it up directly to hdmi1 same issue, but works in hdmi2. What is the problem? I am perplexed.
SOURCE: RCA flat panel L42FHD37 When first
You can easily fix this audio problem by downloading a software upgrade for your HDTV. And you don't have to be a rocket scientist or a brain surgeon either ;)
If you need to find the software upgrade:
Go to RCA.com and click on Support, from there you will click technical support. In technical support, click on the link called Software Download. Scroll to the bottom of the page where you will find 2 links. The first link will tell you how to download the software to a Mini Cruzer USB drive (you need at least 15MB of space) and the second link is the software download itself.
SOURCE: Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
SOURCE: HDMi cable hooked up, but I get an
you have to go to the input button on the remote and push HDMI
SOURCE: No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
