Question about Olympus WS-300M Digital Voice Recorder
WS-300M Olympus Voice Recorder
With a normal dictation machine you can rewind a tad, listen and if you want to overrecord a bit you can just start recording from where you want. We can't figure out how to do this with the digital recorder and someone has said you can. Any ideas/suggestions gratefully received.
  • Anonymous Mar 03, 2008
    How can you rewind to listen to recorded items?
You can rewind a tad and listen, but you can't overrecord, because a digital recorder writes audio information into a data file and saves it. you just can play it back again and record a new file. if you want to cut off a part of your recording, you have to edit the file in an audio editor. - as the olympus stores wma-files, you'll have to convert them into wav format first to edit them. i tried the 'switch' software successfully.
Posted on Oct 15, 2007
6ya staff
SOURCE:
How do you rewind while dictating with the Olympus DM 620?
To rewind, you simply push the rewind button. However, this does not rewind from the point you are at like a tape does, it goes to the beginning of the recording. Once you are in the play mode, pushing rewind will rewind from that point.
Jun 03, 2015 | Olympus Audio Players & Recorders
How to erase dictation
Hello Press and hold telephone and rewind at the same time for about 3 seconds the unit will start to rewind and ERRASE will be flashing on the display
Apr 10, 2014 | Lanier 260T Desktop Cassette Voice...
Rewinding to listen to recording
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
Jun 08, 2009 | Sony ICDP620 Digital Voice Recorder
Picking up dictation where we left off after playback DS 40 voice
Unfortunately with this recorder, if he hits the stop button and rewinds it will go back to the beginning of the file. He may want to look at our DS-2300 or DS-2400 recorders as they both have a feature on them of a NEW button which will allow him to stay in the same file until he presses NEW to create the next recording.
Feb 07, 2009 | Olympus DS-40 Digital Voice Recorder
Hand microphone for DT 100 does not work. Need replacement mic
MR-9 Microphone for DT-1000
The MR-9 Microphone allows direct dictating to the DT-1000 Transcriber and also permits you to control the playback functions remotely. Remote playback functions include Listen, Fast Forward, Rewind, and Stop. Cord extends to approximately 6 feet.
http://www.olympusamerica.com/cpg_section/cpg_audio_acc.asp?val1=1&accessory=76
Jan 28, 2009 | Olympus Pearlcorder DT1000 Desktop...
Is it possible to rewind and overwrite dictation with Olympus VN-2100PC
Unfortunately with this device the VN-2100PC it is not possible to rewind and overwrite any dictations that were done. Each time the record button is pressed and then the stop button is pressed it will create a new file. They may want to look for a DS-2300 or a DS-2400 recorder as these devices have the ability to rewind and allow you to dictate over previously recorded information in the same file. There is a button on these devices called "New" that allows you to stay within the same file until you press New to start the next audio file.
Jan 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
Rewind.
You can rewind and playback only. You can only record by creating a new file.
Sep 09, 2008 | Olympus DS-30 Digital Voice Recorder
Editing? Can dictation be paused, then go back part way and....
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Apr 23, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-300M Digital Voice Recorder Logo
191 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
