1. Fault Phenomenon
The crankshaft rotation speed is normal when starting, but it takes a long time to start, or there are obvious signs that the crankshaft can't start.
2. Failure Cause
Air leakage in intake system; low fuel pressure; clogging of
air filter ; fault of water temperature sensor; malfunction of air Flowmeter; failure of idle speed control valve or additional air valve; failure of cold start injector; leak of injector; Incorrect ignition timing; starting switch to computer connection broken; cylinder compression pressure is too low.
3. Fault Diagnosis and Troubleshooting
A. Perform fault self-diagnosis. If there is a fault code, by the fault code to find the corresponding cause of failure.
B. Check the vacuum of the inlet during idling. If the vacuum degree is less than 667 kPa, the air leakage in the intake system should be checked at the joints, gaskets, vacuum hoses, exhaust gas recirculation system and fuel evaporation recovery system.
C. Check the air filter. If there is a filter plug, it should be cleaned or replaced.
D. If the engine can start normally when the throttle is about 1 / 4 open, and if the throttle is difficult to start when the throttle is completely closed, the idle speed control valve and the additional air valve should be checked to see if the idle speed control valve and the additional air valve are working properly. In cold car idling operation, unplug idle control valve harness or clamp the additional air valve hose with pliers during idle running. If engine speed does not decrease, idle speed control valve does not work properly. Idle speed control valve and its control circuit should be checked.
E. Check fuel pressure. Use a wire to short the two test sockets of the electric gasoline pump, then turn on the ignition switch to make the electric gasoline pump run. In this condition, the fuel pressure should be about 300 kPa. If the pressure is too low, check the oil pressure regulator for oil leakage, gasoline filter plug, gasoline pump maximum pump oil pressure is normal.
