Question about Zebra PRINTER - RW420 - 4 Inch DIRECT THERMAL (DT) RUGGED MOBILE RECEIPT PRINTER - CPCL/EPL/ZPL -... Printhead, Transfer Belt, Cable
Rw420 skip printing
I'm working with the rw420, most of them always got the printing skips where the bar sensor couldn't detect the black mark on the paper. i've tried replaced the bar sensor but still the problem remain. i've even tried resetting & memory reflash using label vista but it doesnt solve my problem. any advice?
  • Zebra Master
  • 783 Answers
Kindly post the output to the command "debug client <printer MAC address>".
Can you also post the output to the command "sh interface detailed zebra".Or in case You Still Having Brother Printer Problem Then Follow Us For On: Printer Support Team
Posted on Jan 29, 2014
6ya staff
SOURCE:
Black ink is skipping lines
Take out cartridge put in a sandwich baggie and shake it; then re-install
Sep 25, 2014 | Canon PIXMA MP610 InkJet Printer
Sending fax error only
Can you post some images of exactly what this looks like? Just make a few copies of a blank sheet of paper if you need to - actually that would probably be better so we'd get nothing but the skid mark. I might be able to make some educated guesses about it once I see it.
Aug 21, 2007 | Brother IntelliFAX 4100 Laser Fax
The print on my documents are not legible. Some words are clear some are not.
From what you've told me, your printer needs to be re-aligned. To find out how to do this, go to Canon's web-site: www.canon.com Select your model, and press " Support ". Download the service manual, and then you'll always have it on your computer any time anything else goes wrong.
Nov 21, 2011 | Canon Office Equipment & Supplies
My Zebra printer is skipping three labels
if black bars on the back of tags, go to control panel, printer pref, advanced settings, tracking media should be mark sensing, then if using QBPOS, when printing select
use black bar indexing
Sep 11, 2011 | Zebra TLP 2824 Printer
Copied cds always skip on axis9s pissing me of even when i dont fill the disk up also now my orginal cds are skipping even though cds are brand new is there a any way i can solve this
Get a laser lens cleaner - the kind with optical quality brushes built in to the disk. If that doesn't do it, it's a more serious hardware issue and will require service or replacement.
Jul 07, 2011 | Nu Mark AXIS 9
Printronix P5210 line printer HOF problem
If you are using a printer that has IGP enabled, you can set the printer to automatically go to the next TOF at the end of the print job. Only if you are using the Graphics portion (printing bar codes and graphics). The option is "Auto FF at ^PN" and you would Enable it.
Dec 29, 2008 | Printronix Line Matrix P5210 Printer
HP OfficeJet K80 All-In-One Problem: Constant Request To Realign Cartridge
This could be a hit or miss but what does it hurt to try...
I had this problem with the color cartridge a while back. Worked tirelessly with HP support and somehow got it to work. Since it was on the phone and a while back, I fogot! Now is the time for the black cartridge. Same thing. Reading somewhere here about skipping the test I gave it a try and it worked.
- Unplug the printer for 1 minute (not sure if this is necessary but it doesn't hurt).
- Replug.
- When the "Press Enter to align..." message comes up, PRESS and HOLD Enter.
- While holding Enter, press Menu. The screen skips the test part and shows the date.
- Release Enter. Now you can print. Actually, I could print, you are on your own now.
Aug 18, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
"Skip Blank Page" Set to 0.1% Yet still skips pages with footers and headers
We have the same problem where I work. We use a black texta and draw a line down the middle of the page. This gives the scanner a point to pick up apart from the minimal text at the top. However, this will only work if you are happy to have a line on your scanned document!
Apr 09, 2008 | Canon DR-9080C Path-Through Scanner
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Zebra PRINTER - RW420 - 4 Inch DIRECT THERMAL (DT) RUGGED MOBILE RECEIPT PRINTER - CPCL/EPL/ZPL -... Printhead, Transfer Belt, Cable Logo
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Gateway information...
Marvin
Marvin
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
