Question about Coffee Makers & Espresso Machines
The filter basket overflows while brewing
It seems like the filter basket is filling with water too quickly.  I've tried to adjust the timer, but it still overflows sometimes.
  • 3 Answers
MORE COFFEE
Posted on Mar 17, 2009
6ya staff
SOURCE:
A breville you brew bdc600xll coffee maker basket overflowing water and grounds
I have that problem also when I use the wrong filter in my BUNN but when I use only BUNN filters it does not do it . you could try them they seem to be a little deeper .
Oct 09, 2015 | Breville BDC600XL Coffee Maker, You Brew...
Cuisinart brew on demand coffee maker
what about on/off switch, does it seem ok.
regards,
dont rate it untill fully satisfied
Aug 23, 2008 | Cuisinart DCC-1200 Coffee Maker
I bought a used stf 15 bunn coffee maker , i hooked it up to the water line , and plugged it in , my problem is that it will run about enough water for about 2 pots , i hear it click when the first pot...
Yes that is possible. There is a pressure regulator that is normally mounted on the back of the coffee maker. On older models the filter and pressure regulator may be inside the cabinet accessable by removing the bottom panel of the coffeemaker. The pressure regulator is a hexagon shaped usually brass fitting about 3 inches in length. The filter looks much the same. Both of these brass fittings should be somewhere in the water line between the wall faucet and the water inlet of the coffee maker. If not there the unit will overflow if you water pressure is over 40 psi in your location. These fittings are available from restaurant equipment stores and on Ebay for example. There is one other thing you may try. If you take off the panel directly behind the coffee pot you will see two adjustments. One is a temperature adjustment and looks like a small pin sticking up with a smaller pin at 90 degrees from it. The other adjustment is a timer. There will be a dial on the timer. This timer sets the amount of water per cycle by controlling the time that the fill valve stays open. Turn the timer counterclockwise by about 25% and hit the brew button again. If it overflows reduce the timer again. If you don't have a pressure regulator, you may not be able to turn the timer low enough to prevent the overflow situation. Good luck!
Sep 21, 2010 | Kitchen Ranges
Had about a week. if i fill with 50 ounces of
Try taking the filter out, and turn the sprayhead off the unit. Put the basket back on, and try pouring clear water through the unit. If the water runs through fine, you either have a plugged sprayhead or are using too finely ground coffee. Look at the holes in the sprayhead, and make sure that none of the holes are plugged. If the basket still overflows, try using a drill bit to make the hole in the funnel a little larger. Good luck.
Mar 06, 2010 | Bunn BT10B Coffee Maker
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
Oct 05, 2009 | Bunn VPR Coffee Maker
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Water sitting in well (where the coffee goes) - doesn't drain
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
The brew-pause feature is somewhat limited. You can remove the caraffe quickly, pour, and quickly reinsert it, but there is going to be some drippage during the process. You also have to replace the caraffe back in place quickly, or the coffee will overflow the basket.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 21, 2009 | Cuisinart DCC-1200 Coffee Maker
Water overflow
If the water is running out the seams in the plastic BEFORE you brew anything, it is a defect or design flaw. I bought one that looks like the one pictured and it did the same thing. So did the replacement.
If the overflow occurs during brewing, verify the following:
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Jan 09, 2009 | KitchenAid KCM511 Coffee Maker
Spacemaker? Digital Coffeemaker-overflows during brewing with grounds everywhere.
I've read of this problem from other users of the newer Spacemakers and believe I know what's going on. Black & Decker used too strong a spring in the mechanisms involved in the "sneak a cup" feature which keeps the small tab or finger underneath the basket from opening and allowing the coffee to run into the decanter.
My suggestion would be to make certain that the tab that presses against the bottom of the basket is open when you insert the carafe. Not owning one of these units I can't state categorically that this will solve your problem, but all of the Spacemakers are fundamentally the same, just some cosmetic and design differences between them.
If it turns out that the tab is open when you go to bed and the basket still overflows it's possible the spring is so strong that it's moving the carafe away from the back of the unit, causing the tab to close against the basket. If that's the case I would figure out how to remove the spring without breaking anything in the process, then take it down to your local Ace Hardware and get a same sized but weaker spring. That should solve the problem permanently.
Sep 14, 2008 | Black & Decker SpaceMaker ODC325 Coffee...
Coffee Makers & Espresso Machines Logo
346 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Pierre Laplante
Charles Tidwell
Marvin
Marvin
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
